2006 Mar 18 Sat 8:57 pm
2006 Mar 19 Sun 12:24 pm
2006 Mar 19 Sun 10:18 pm
2006 Mar 20 Mon 3:30 pm
2006 Mar 20 Mon 4:10 pm
2006 Mar 20 Mon 8:14 pm
2006 Mar 22 Wed 1:52 pm
Howdy…Just got of the phone with our resident Stude Dude and this is what he thinks the situation is. He says that he is not an expert on Conestogas but he is very knowledgeable on Stude wagons in general. He thinks that the frames are the same for Conestoga, as well as 2 and 4 door sedans for 54 & 55. He thinks that the differences in frame part numbers is the placement of the riveted body supports in the frame. He says that if you inspect the frame you should see that there a number of unused holes for moving the body mount placement around to suit the applicable model. Does this frame sport these extra holes?
He also says that he does not think that there were any differences between Champ and Commander Frame thickness back then. He says that they were all weak in the upper A-Frame/Shock tower areas from 53 to 55 and that the fix was to install a reinforcing plate in the tower. He states that there definitely was a thickness difference between 6 & 8 cylinder frames upon the advent of the Lark
Hope this helps. Let us know what you find
2006 Mar 22 Wed 10:50 pm
2006 Mar 26 Sun 9:56 am
2026 Mar 21 Sat 1:06 pm
