How to Get the Vowed Mace in Aion 2: A Complete Guide
Postby Thornshade » 2026 Jan 09 Fri 2:38 am
The Vowed Mace is a Legend-grade Mace weapon exclusive to the Cleric class in Aion 2. It offers several useful stats, making it a popular choice for Cleric players who want to improve their combat abilities. In this section, we'll break down its key attributes and features to help you understand its usefulness in the game.
What Are the Stats of the Vowed Mace?
Here are the key stats of the Vowed Mace:
Item Level: 49
Attack: 175 - 225
Accuracy: 100
Critical Hit: 50
Block: 50
PvE Damage Boost: Present (exact details not available)
Manastone Slots: 3
What Do These Stats Mean?
Attack: This is the range of damage your Cleric can deal with the Vowed Mace. A higher value means more damage, which is important in both PvE and PvP situations.
Accuracy: The accuracy of 100 makes this weapon reliable in hitting your enemies, especially important in tougher content where enemies have high evasion.
Critical Hit: With a 50-point critical hit bonus, this weapon helps increase your chances of landing a critical hit, which can deal significantly more damage than normal attacks. This is especially useful when facing bosses or enemies with high health.
Block: The 50-block value allows the Cleric to defend against attacks more effectively, offering some survivability in tougher battles.
PvE Damage Boost: While the specific percentage isn't given, the PvE damage boost is another way the Vowed Mace improves your performance against PvE content like dungeons, raids, and quests.
Manastone Slots: The 3 manastone slots mean you can further enhance the weapon with additional stat bonuses. This is a great way to customize the weapon to suit your playstyle, whether you're focusing on damage, defense, or support abilities.
How Do You Obtain the Vowed Mace?
Currently, the Vowed Mace can be obtained as a drop in the Abyss. This is a high-level PvP zone that is typically populated by other players and dangerous enemies. Most players can expect to encounter this weapon through regular progression in the Abyss, but it’s worth noting that it’s not guaranteed to drop every time.
The exact details of the drop rate and the areas in the Abyss where the Vowed Mace can be obtained are still unclear, but as with many rare drops in Aion 2, your chances may increase with higher-level content or special events.
In general, the Vowed Mace isn’t easy to come by, so many players will either grind the Abyss to try for a drop or consider other ways to acquire it.
Can You Craft the Vowed Mace?
At the moment, there are no crafting details available for the Vowed Mace. This means you cannot create it through traditional crafting methods like some other weapons in the game. Most players rely on drops or marketplace transactions to acquire such rare items.
If you're determined to get your hands on this weapon, you’ll likely need to grind in the Abyss or find other means of obtaining it, such as buying Aion 2 gold to use in the marketplace.
How Much is the Vowed Mace Worth?
If you manage to sell a Vowed Mace, you can expect to fetch around 12,220 gold. This makes it a valuable item, but most players will likely keep it for themselves due to its strong stats and usefulness in PvE content. Selling it might be tempting, but holding onto it can provide long-term benefits for your Cleric’s performance in both solo and group content.
Should You Focus on Getting the Vowed Mace?
Whether or not you should focus on getting the Vowed Mace depends on your goals as a Cleric. If you’re looking to improve your PvE performance and tankier capabilities, this weapon can make a big difference. Its high accuracy, critical hit, and block make it effective in dealing damage while maintaining survivability in difficult situations.
However, since the Vowed Mace is a rare drop from the Abyss, you’ll need to be prepared for some grind. If you’re not into farming for specific items, or if you want to speed up the process, you might consider buying Aion 2 gold to purchase the weapon from the marketplace, if that becomes available.
How to Maximize the Use of the Vowed Mace
Once you have the Vowed Mace, there are several ways to maximize its potential:
Manastone Enhancements: Since the weapon has 3 manastone slots, you should carefully choose manastones that match your playstyle. For example, focusing on manastones that boost your damage or defense can help make your Cleric more versatile.
Pair with Support Gear: The Vowed Mace is excellent in PvE content, but for maximum effectiveness, pair it with other support gear that increases your healing output or survivability.
Use for Boss Fights: The critical hit and PvE damage boost make the Vowed Mace ideal for boss fights. These fights often have higher difficulty levels and require maximum damage output to complete successfully.
The Vowed Mace is a powerful weapon that offers a variety of benefits for Cleric players. With its strong attack, accuracy, critical hit, and block, it can be a game-changer in both PvE content and some PvP encounters. However, due to its rarity and current availability only as an Abyss drop, acquiring it might take some time and effort.
If you’re not ready to grind, or if you’re looking for a quicker way to upgrade, you might want to consider using Aion 2 gold to buy the weapon from other players or in the marketplace. Just be sure to consider the long-term benefits of holding onto the Vowed Mace before you decide to sell it.
Thornshade
Re: How to Get the Vowed Mace in Aion 2: A Complete Guide
Postby yourbuns » 2026 Apr 01 Wed 1:51 am
Postby yourbuns » 2026 May 11 Mon 11:11 pm
