Arc Raiders: Burletta Quest Guide
Postby Thornshade » 2026 Jan 17 Sat 12:28 am
What is the Burletta and Why Does It Matter?
The Burletta is an uncommon semi-automatic pistol that uses light ammo. Its main strengths are accuracy and stable damage output, while its weaknesses are low armor penetration and modest stealth. In practice, this means it works well for mid-range encounters and picking off smaller targets, but it won’t perform well against heavily armored enemies or when you need a stealth-focused build.
Key stats in practice:
Damage: 10
Fire Rate: 28
Range: 41.7
Stability: 74.5
Agility: 84.4
Stealth: 24
Players often use it as a reliable sidearm, especially early in the game, because it doesn’t require rare ammo and is easy to maintain.
Where Can I Get the Burletta?
There are three main ways to acquire a Burletta:
Scavenging – You can occasionally find Burletta pistols in the environment, usually in weapon caches or after defeating enemies. It’s not guaranteed, so don’t rely solely on this method.
Crafting – You can craft a Burletta if you have a Burletta Blueprint, which is rewarded from the Industrial Espionage quest. This is usually the most reliable method for obtaining the weapon early on.
Buying from Tian Wen – NPC vendor Tian Wen sells Burletta pistols at set prices. For players who have extra coins and want to avoid scavenging, this is straightforward but costs more in the long term.
In many communities, you’ll see players choose the blueprint route because it allows them to sell blueprints arc raiders for cash if they don’t want to craft the weapon immediately. This can provide a quick boost in-game currency.
How Do I Craft the Burletta?
Crafting requires a Gunsmith 1 skill and the following ingredients:
3× Mechanical Components
3× Simple Gun Parts
Burletta Blueprint
Crafting produces a Burletta I, which is the base version of the weapon. From there, upgrades are available to improve performance.
How Does Upgrading Work?
Upgrading the Burletta improves reload time and durability. Here’s a practical breakdown:
Burletta I → Burletta II
Ingredients: 1× Burletta I, 3× Mechanical Components, 1× Simple Gun Parts
Effect: 16.6% reduced reload time, +10 durability
Burletta II → Burletta III
Ingredients: 1× Burletta II, 3× Mechanical Components, 1× Simple Gun Parts
Effect: 33.3% reduced reload time, +20 durability
Burletta III → Burletta IV
Ingredients: 1× Burletta III, 4× Mechanical Components, 1× Simple Gun Parts
Effect: 50% reduced reload time, +30 durability
In practice, most players stop at Burletta III unless they want maximum efficiency for sustained combat, because the fourth upgrade is more resource-intensive without dramatically changing performance in casual scenarios.
How Do I Repair the Burletta?
Weapon durability decreases with use, so repair is necessary to maintain effectiveness. Repair costs scale with the level:
Burletta I: 1× Mechanical Components, 2× Simple Gun Parts (+50 durability)
Burletta II: 2× Mechanical Components, 2× Simple Gun Parts (+55 durability)
Burletta III: 3× Mechanical Components, 3× Simple Gun Parts (+60 durability)
Burletta IV: 4× Mechanical Components, 4× Simple Gun Parts (+65 durability)
Most players repair when durability drops below 50% because using a degraded Burletta reduces your effectiveness and can cost more in the long run if you let it break completely.
Recycling and Salvaging
If you have extra Burletta pistols or want to recover materials, you can recycle or salvage them:
Recycling returns both mechanical components and simple gun parts, usually equivalent to or slightly less than what was used in crafting.
Salvaging only returns simple gun parts, making it less efficient but faster if you just need basic materials.
Practical tip: players often recycle older versions of the Burletta to gather components for upgrades or other weapons. Salvaging is usually reserved for when you need gun parts quickly without worrying about mechanical components.
Practical Tips from Experienced Players
Focus on upgrading the first Burletta you craft. The improved reload time and durability make it a viable mid-game sidearm.
Use Burletta I or II for early-game missions where enemies are lightly armored. Only craft Burletta III or IV if you are tackling longer raids or want durability for multiple missions.
Keep track of ammo. Light ammo is easier to find than heavy, but running out in the middle of combat can be a problem, especially in extended missions.
If you find multiple blueprints, you can sell blueprints arc raiders for cash to fund other upgrades or equipment. This is often more efficient than crafting every blueprint immediately.
Always repair before major missions. Even small durability losses can impact fire rate and overall effectiveness in tight situations.
The Burletta is a versatile, mid-tier weapon that rewards careful upgrading and maintenance. Its main advantages are accuracy, agility, and reliable damage, while its weaknesses—low stealth and armor penetration—mean it isn’t a one-size-fits-all solution. Crafting, upgrading, repairing, and recycling are all part of a practical strategy for making the most of this weapon.
By understanding its stats, acquisition methods, and maintenance requirements, you can integrate the Burletta into your loadout effectively, whether you are farming quests or tackling mid-level raids.
Support Guide: Arc Raiders Heavy Gun Parts Blueprint Location & Farm Guide
Thornshade
Re: Arc Raiders: Burletta Quest Guide
Postby yourbuns » 2026 Apr 01 Wed 2:01 am
Postby yourbuns » 2026 May 11 Mon 11:22 pm
