More Stude Hot Rod parts...
Postby Mike » 2011 Nov 03 Thu 8:21 pm
The cam grinder that's doing the roller cams for us is also going to make adjustable upper timing gears.
Again please go the the Stude Racing site to the thread below -
http://racingstudebakers.com/foo/viewto ... f=1&t=2405
This gear will be affordable and work under the stock timing gear cover. If you want to get your camshaft of ANY brand to the closer location it was designed to be in, think about one of these.
Not sure of the exact cost yet (hopefully this weekend) but it won't be too much more than the aftermarket aluminum gears currently available.
Re: More Stude Hot Rod parts...
Postby hi-per al » 2011 Nov 03 Thu 9:18 pm
Mike...did I happen to mention that I am in for 2 and possibly 1 or 2 more?
I trust that this helps.
BTW....Nobody in ConestogaLand got any designs on warming up thier ole girls? These gears are an absolutely thrifty way to positively alter the performance of that Studey V8!
Postby Mike » 2011 Nov 04 Fri 10:13 am
Hey Al -
Yes...you did....thanks.
And you're right, a coupla degrees in either direction can change the engine performance a great deal.
Postby yourbuns » 2026 Apr 01 Wed 6:05 am
Users browsing this forum: No registered users and 9 guests
