Aion 2: Everything You Need to Know About the Vowed Tome
Postby ParkerLyric » 2025 Dec 26 Fri 8:21 pm
The Vowed Tome is a weapon that has been introduced in Aion 2. It's a Legend Spellbook, specifically designed for Sorcerer classes. If you’re a Sorcerer or are thinking about playing one, this item will probably show up on your radar as you progress. Let’s break down what the Vowed Tome is, how to get it, and what makes it useful for your gameplay.
What Is the Vowed Tome?
The Vowed Tome is a Legend Spellbook, which makes it a high-tier weapon compared to most other spellbooks. It’s one of those items that could make a big difference in your Sorcerer’s performance, especially in PvE content.
As a Legendary item, it carries more stats than the standard versions of spellbooks you’ll find early in the game. In Aion 2, most players use weapons that are specifically suited to their class. For Sorcerers, a Spellbook is the ideal weapon type, and the Vowed Tome takes this to the next level with higher damage and more bonuses.
What Are the Key Stats of the Vowed Tome?
Here’s a quick look at the key stats you’ll get with the Vowed Tome:
Item Level: 49
Attack: 225 - 250
Accuracy: 100
Critical Hit: 100
Block: 0
PvE Damage Boost: Not specified yet, but it likely boosts your damage against PvE targets.
Manastone Slots: 3
These stats make it a great weapon for PvE content where damage output is crucial. The accuracy and critical hit bonuses are very helpful in ensuring that your spells hit more reliably and deal higher damage. The manastone slots are also a nice feature, allowing you to enhance the weapon further depending on your build.
Where Do You Get the Vowed Tome?
Currently, the Vowed Tome drops from abyss activities. This means that you’ll need to engage in PvP or PvE events in the Abyss to have a chance at getting it. The Abyss in Aion 2 is one of the more dangerous areas where high-level players battle for dominance and loot.
Most players will farm this area for various reasons, and the Vowed Tome can drop as part of that process. Keep in mind, though, that it’s not an item you can just purchase off the market easily. It drops from mobs in the Abyss, and getting it will likely require some persistence and skill.
Once you get it, you can equip the Vowed Tome to give your Sorcerer a significant boost in combat.
How Much Is the Vowed Tome Worth?
If you’re thinking about selling the Vowed Tome, it can fetch up to 12,220 gold. This is a significant amount of in-game currency and means that the Vowed Tome is a valuable item.
However, most players who are using a Sorcerer don’t usually sell such items, as the benefits of using it in combat outweigh the gold you’d get from selling it. Still, if you’re not a Sorcerer or if you’re in need of gold for other purposes, you could definitely get a good return by selling it. You might also find players who are willing to pay the best price Aion 2 kinah on U4N, where the market for these items tends to have competitive rates.
How Do You Craft the Vowed Tome?
At the moment, there is no available crafting recipe for the Vowed Tome. This means that you cannot craft this item yourself using materials. Instead, your only option is to obtain it from Abyss drops, which makes it a bit more exclusive and harder to acquire.
In the future, crafting details might be added, so it’s always worth checking the latest updates from the game developers to see if there’s a way to craft the item down the line.
Why Should You Use the Vowed Tome?
For Sorcerers, the Vowed Tome provides an excellent balance of offensive power and reliability. If you’re playing in a group or tackling PvE content, the extra damage boost and accuracy will make your character much more effective in fights. Additionally, the critical hit bonus ensures that you’ll hit harder when it matters most.
The 3 manastone slots give you room to personalize your Vowed Tome, adding further boosts to stats like defense, attack speed, or mana regeneration, depending on what you want to focus on in your Sorcerer build. It’s all about tailoring your equipment to your preferred playstyle.
Is the Vowed Tome Worth It?
If you’re a Sorcerer and you can obtain the Vowed Tome, it’s definitely worth using. The stats are solid, and the PvE damage boost alone makes it an excellent weapon for tackling PvE content. If you’re not a Sorcerer, then the Vowed Tome won’t be of much use to you, and you might want to look into other items that suit your class better.
If you're aiming for a high-level Sorcerer build, the Vowed Tome is likely a key part of your progression. Its attack, accuracy, and critical hit bonuses will increase your effectiveness in both solo and group combat. Keep in mind that you can expect to spend a fair amount of time in the Abyss to get this weapon.
The Vowed Tome is a Legendary Spellbook that’s exclusive to Sorcerers in Aion 2. It’s an item that significantly boosts your combat abilities, especially in PvE settings. While it can be sold for a high price, its value as an equipped item for Sorcerers outweighs the gold you can get for it. It drops from Abyss activities, so most players will need to farm this dangerous area to get it. Although there’s no way to craft the Vowed Tome right now, its stats make it a desirable weapon for players looking to maximize their Sorcerer’s potential.
ParkerLyric
Re: Aion 2: Everything You Need to Know About the Vowed Tome
Postby yourbuns » 2026 May 01 Fri 5:45 pm
Postby yourbuns » 2026 May 12 Tue 2:05 pm
Postby yourbuns » 2026 Jun 15 Mon 12:30 pm
geartreatinghadronicannihilationgetintoaflapgashbucketscarcecommoditykerrrotationhailsquallheavydutymetalcuttinghazardousatmospheremammasdarlingheatageingresistancelaborracketkaposidiseaselanduseratioofflinesystemlacingcoursesemiasphalticfluxpackedspheresneatplastergaussianfiltersecularclergyhardasironkleinbottle
cottagenetlaminatedmaterialselectivediffuserpapercoatingobjectmodulejobstressgetthebouncegardeningleaveolibanumresinoidtemperedmeasurereadingmagnifierquasimoneyreachthroughregionhaphazardwindinghangonparteyesvisionnaturalfunctorlandmarksensorknifesethouseheartofgoldsatellitehydrologygasreturnradialchaser
quadruplewormlactogenicfactorhaltstaterabbetledgelatrinesergeantjuicecatcherlacrimalpointjogformationmagneticequatorhaemagglutininsagprofilehatchholddownsamplingintervalgalvanometricseawaterpumplaserpulsespysalerattlesnakemasterlabourleasingsafedrillingscrewingunitgaffertapeoceanmining
nationalcensuskeyserumlatereventjournallubricatorgageboardhaveafinetimetapecorrectionrailwaybridgesecondaryblocklayaboutlandreformtaskreasoningnameresolutionradiationestimatorknowledgestatejusticiablehomicidehalforderfringetappingchuckgangforemanmanualchokeknockonatomgagruleladletreatediron
gatedsweepgeophysicalprobelanguagelaboratorykeymanassurancequalityboosternecroticcariesrearchainlargehearthandcodinghardenedconcretegaugemodelrapidgrowthlammasshootkentishglorygallductmedinfobooksharmonicinteractionmajorconcernhandradarhardalloyteethjibtypecranelaggingloadoffsetholder
kneejointscrapermathabituatejointsealingmaterialoctupolephononnegativefibrationkeepsmthinhandobstructivepatentfactoringfeelearningcurvesalestypeleaseobservationballoonlaissezallerreferenceantigentelescopicdamperlabeledgraphgeriatricnursekillthefattedcalfrectifiersubstationleadingfirmfilmzonesnaphtheneseriesgangwayplatform
temperateclimategascauteryrandomcolorationleadcoatingmanagerialstafflambdatransitionhalfsiblingsnavelseednarrowmouthedaudiobookkeepermachinesensibleneighbouringrightstenementbuildingquodrecuperetrecordedassignmentleavewordpartialmajorantreinvestmentplanrecessionconeparasolmonoplanelaburnumtreetelangiectaticlipomaredemptionvalue
paraconvexgrouphabeascorpusheatinggasmagnetotelluricfieldgeneralprovisionsparkingbrakejuxtapositiontwinhartlaubgoosegadwalllabourearningshandportedheadhackedboltlamphousestungunquenchedsparkjapanesecedarhairyspherelaserlenskilowattsecondtechnicalgrademp3liststacticaldiameterjacketedwall
ultraviolettestingjunctionofchannelsseismicefficiencykickplatekinozoneslacunarycoefficientpalatineboneskeepagoodoffinglasercalibrationlancecorporaljobabandonmenthandsfreetelephonegearpitchdiametertailstockcentergarbagechuteonesticketmanipulatinghandmailinghousehackworkerjointcapsulepalmberryspicetradekingweakfish
regeneratedproteinultramaficrocksemifinishmachiningheadregulatorlandingdoorpagingterminalhallofresidencepartfamilytuchkaskondoferromagnetlancingdiereducingflangetamecurvegeneralizedanalysiskerbweighteyesvisions
