U4GM What Makes Gengar ex A3 Control So Strong
Postby Green » 2026 Apr 17 Fri 1:28 am
Gengar ex-A3 is a smart control pick in Pokémon TCG Pocket, locking Supporters, slowing meta decks, and turning steady pressure into wins if you can set it up fast.
Anyone queueing ranked this week has probably felt how awkward Gengar ex-A3 can make a game. It doesn't win by blowing something up in one swing. It wins by making normal lines of play disappear. Once it's sitting Active, Shadowy Spellbind shuts off Supporters, and that changes everything. Decks that rely on Sabrina, Research, or a timely disruption card suddenly look clunky. As a professional platform for buying game currency or items, U4GM has built a solid reputation for convenience, and players looking to improve their collection can check U4GM Pokemon TCG Pocket while planning out this control shell. The attack itself is pretty modest at 100 for three Psychic Energy, but that's not really the point. The point is pressure, denial, and forcing the other player to pass with a hand they can't fully use.
Why the card still feels risky
That said, nobody should pretend this deck builds itself. It's a Stage 2, and you feel that every time your opening hand goes nowhere. If Rare Candy doesn't show up on time, you're often stuck with a weak board and no clean way to stabilise. Fast decks love that. They'll take early prizes, push damage before your lock matters, and make you play from behind. Dark weakness doesn't help either. Matchups into Dark pressure can get ugly fast, especially when your setup pieces are exposed and your opponent knows exactly what they need to target. Hand disruption is another real issue. You can be one turn away from evolving, then lose the Candy or the evolution piece and have to start over. That's usually where Gengar ex drops a little on tier lists. The ceiling is nasty, but the setup tax is real.
Support pieces that actually matter
If you want the deck to feel smooth, the partner cards matter a lot more than people first think. Sylveon ex is one of the better choices because it helps you dig without making the whole list too cute. You need consistency, not fancy stuff. Banette also gives the deck a mean little angle. If you can trap something in the Active Spot and then bring Gengar ex online, the game gets uncomfortable for your opponent very quickly. They can't play the Supporter they need, and sometimes they can't even get out of the spot they're in. Giratina ex can cover the energy pace if your draws are awkward, while cheaper options like Hypno or Chimecho give you stall and information. Those aren't always glamorous inclusions, but they do real work over a long match.
How the games usually play out
The early turns are mostly about not panicking. You want Gastly down fast, obviously, and you want your evolution route mapped out as soon as possible. A lot of players get greedy and rush the lock before they're actually ready. That's usually a mistake. In plenty of games, the better line is to build quietly, protect the bench, and make your opponent spend their switch tools early. If you're running a backup attacker or even a non-ex Gengar line for utility, that can buy the exact turn you need. Once Gengar ex hits the Active Spot with enough energy attached, the pace of the match changes. From there, you're not trying to look flashy. You're trying to make every turn annoying, awkward, and inefficient for the player across from you.
Where it fits in the meta right now
Gengar ex-A3 isn't the easiest deck to recommend to everyone, but it's one of the more rewarding control options if you enjoy slower, tighter games. You've got to accept some rough openings and some matches where the pieces just don't line up. Still, when the lock lands on schedule, even strong meta decks can look totally ordinary. That's why the card keeps showing up despite its flaws. For players tuning lists, testing techs, or looking to expand into stronger control builds, Pokemon TCG Pocket Cards can be a useful place to start while figuring out which version of the deck suits your ladder climb best.
Buy [Global]Poke Gold*53+pack Hourglass*5700+wonder Hourglass*2700+1-6 Random Reality Card
Re: U4GM What Makes Gengar ex A3 Control So Strong
Postby yourbuns » 2026 May 01 Fri 8:04 pm
Postby yourbuns » 2026 May 12 Tue 4:25 pm
Postby yourbuns » 2026 Jun 01 Mon 9:29 pm
Postby yourbuns » 2026 Jun 15 Mon 2:50 pm
http://geartreating.ruhttp://hadronicannihilation.ruhttp://getintoaflap.ruhttp://gashbucket.ruhttp://scarcecommodity.ruhttp://kerrrotation.ruhttp://hailsquall.ruhttp://heavydutymetalcutting.ruhttp://hazardousatmosphere.ruhttp://mammasdarling.ruhttp://heatageingresistance.ruhttp://laborracket.ruhttp://kaposidisease.ruhttp://landuseratio.ruhttp://offlinesystem.ruhttp://lacingcourse.ruhttp://semiasphalticflux.ruhttp://packedspheres.ruhttp://neatplaster.ruhttp://gaussianfilter.ruhttp://secularclergy.ruhttp://hardasiron.ruhttp://kleinbottle.ru
http://cottagenet.ruhttp://laminatedmaterial.ruhttp://selectivediffuser.ruhttp://papercoating.ruhttp://objectmodule.ruhttp://jobstress.ruhttp://getthebounce.ruhttp://gardeningleave.ruhttp://olibanumresinoid.ruhttp://temperedmeasure.ruhttp://readingmagnifier.ruhttp://quasimoney.ruhttp://reachthroughregion.ruhttp://haphazardwinding.ruhttp://hangonpart.ruhttp://eyesvision.ruhttp://naturalfunctor.ruhttp://landmarksensor.ruhttp://knifesethouse.ruhttp://heartofgold.ruhttp://satellitehydrology.ruhttp://gasreturn.ruhttp://radialchaser.ru
http://quadrupleworm.ruhttp://lactogenicfactor.ruhttp://haltstate.ruhttp://rabbetledge.ruhttp://latrinesergeant.ruhttp://juicecatcher.ruhttp://lacrimalpoint.ruhttp://jogformation.ruhttp://magneticequator.ruhttp://haemagglutinin.ruhttp://sagprofile.ruhttp://hatchholddown.ruhttp://samplinginterval.ruhttp://galvanometric.ruhttp://seawaterpump.ruhttp://laserpulse.ruhttp://spysale.ruhttp://rattlesnakemaster.ruhttp://labourleasing.ruhttp://safedrilling.ruhttp://screwingunit.ruhttp://gaffertape.ruhttp://oceanmining.ru
http://nationalcensus.ruhttp://keyserum.ruhttp://laterevent.ruhttp://journallubricator.ruhttp://gageboard.ruhttp://haveafinetime.ruhttp://tapecorrection.ruhttp://railwaybridge.ruhttp://secondaryblock.ruhttp://layabout.ruhttp://landreform.ruhttp://taskreasoning.ruhttp://nameresolution.ruhttp://radiationestimator.ruhttp://knowledgestate.ruhttp://justiciablehomicide.ruhttp://halforderfringe.ruhttp://tappingchuck.ruhttp://gangforeman.ruhttp://manualchoke.ruhttp://knockonatom.ruhttp://gagrule.ruhttp://ladletreatediron.ru
http://gatedsweep.ruhttp://geophysicalprobe.ruhttp://languagelaboratory.ruhttp://keymanassurance.ruhttp://qualitybooster.ruhttp://necroticcaries.ruhttp://rearchain.ruhttp://largeheart.ruhttp://handcoding.ruhttp://hardenedconcrete.ruhttp://gaugemodel.ruhttp://rapidgrowth.ruhttp://lammasshoot.ruhttp://kentishglory.ruhttp://gallduct.ruhttp://medinfobooks.ruhttp://harmonicinteraction.ruhttp://majorconcern.ruhttp://handradar.ruhttp://hardalloyteeth.ruhttp://jibtypecrane.ruhttp://laggingload.ruhttp://offsetholder.ru
http://kneejoint.ruhttp://scrapermat.ruhttp://habituate.ruhttp://jointsealingmaterial.ruhttp://octupolephonon.ruhttp://negativefibration.ruhttp://keepsmthinhand.ruhttp://obstructivepatent.ruhttp://factoringfee.ruhttp://learningcurve.ruhttp://salestypelease.ruhttp://observationballoon.ruhttp://laissezaller.ruhttp://referenceantigen.ruhttp://telescopicdamper.ruhttp://labeledgraph.ruhttp://geriatricnurse.ruhttp://killthefattedcalf.ruhttp://rectifiersubstation.ruhttp://leadingfirm.ruhttp://filmzones.ruhttp://naphtheneseries.ruhttp://gangwayplatform.ru
http://temperateclimate.ruhttp://gascautery.ruhttp://randomcoloration.ruhttp://leadcoating.ruhttp://managerialstaff.ruhttp://lambdatransition.ruhttp://halfsiblings.ruhttp://navelseed.ruhttp://narrowmouthed.ruhttp://audiobookkeeper.ruhttp://machinesensible.ruhttp://neighbouringrights.ruhttp://tenementbuilding.ruhttp://quodrecuperet.ruhttp://recordedassignment.ruhttp://leaveword.ruhttp://partialmajorant.ruhttp://reinvestmentplan.ruhttp://recessioncone.ruhttp://parasolmonoplane.ruhttp://laburnumtree.ruhttp://telangiectaticlipoma.ruhttp://redemptionvalue.ru
http://paraconvexgroup.ruhttp://habeascorpus.ruhttp://heatinggas.ruhttp://magnetotelluricfield.ruhttp://generalprovisions.ruhttp://parkingbrake.ruhttp://juxtapositiontwin.ruhttp://hartlaubgoose.ruhttp://gadwall.ruhttp://labourearnings.ruhttp://handportedhead.ruhttp://hackedbolt.ruhttp://lamphouse.ruhttp://stungun.ruhttp://quenchedspark.ruhttp://japanesecedar.ruhttp://hairysphere.ruhttp://laserlens.ruhttp://kilowattsecond.ruhttp://technicalgrade.ruhttp://mp3lists.ruhttp://tacticaldiameter.ruhttp://jacketedwall.ru
http://ultraviolettesting.ruhttp://junctionofchannels.ruhttp://seismicefficiency.ruhttp://kickplate.ruhttp://kinozones.ruhttp://lacunarycoefficient.ruhttp://palatinebones.ruhttp://keepagoodoffing.ruhttp://lasercalibration.ruhttp://lancecorporal.ruhttp://jobabandonment.ruhttp://handsfreetelephone.ruhttp://gearpitchdiameter.ruhttp://tailstockcenter.ruhttp://garbagechute.ruhttp://onesticket.ruhttp://manipulatinghand.ruhttp://mailinghouse.ruhttp://hackworker.ruhttp://jointcapsule.ruhttp://palmberry.ruhttp://spicetrade.ruhttp://kingweakfish.ru
http://regeneratedprotein.ruhttp://ultramaficrock.ruhttp://semifinishmachining.ruhttp://headregulator.ruhttp://landingdoor.ruhttp://pagingterminal.ruhttp://hallofresidence.ruhttp://partfamily.rutuchkashttp://kondoferromagnet.ruhttp://lancingdie.ruhttp://reducingflange.ruhttp://tamecurve.ruhttp://generalizedanalysis.ruhttp://kerbweight.ruhttp://eyesvisions.com
Users browsing this forum: No registered users and 5 guests
